The DOS Protection application could not setup the kernel DOS device driver correctly.
This problem will cause the DOS Protection application to fail at startup. If this happens again after a reboot, get in touch with Extreme Networks Technical Support (Who will need to get in touch with Engineering).
Error
Could not set dos device fd %dev% to O_NONBLOCK
| Name | Type |
| dev | sInt |
